Home Soundcraft Forum Soundcraft Mixing Consoles
Ui24 multitrack recording question
What is the functionality of the 'soundcheck' feature? The documentation is nonexistent. All I know, is that when I activate soundcheck, i have no audio and all the sliders disappear on the Gains screen. BTW, I only use the monitor channels in my home setup. I understand the two channel USB recording feature, and have been able to record with the multitrack, but as I said, the documentation is seriously deficient re multitrack recording. I am also NOT using a DAW yet, just recording to a USB stick.
  • From manual section 5.6
    SOUNDCHECK
    Soundtcheck is basically another set of patches. It can be used to set up a trial mix via pre-recorded files
    on USB for example or work on a straight live soundcheck or a mixture of both. Setup is the same as it is
    for normal patching applications. Once the Soundcheck mode is engaged the selection panel will be green.
    There are two ways to activate Soundcheck either through the SETTINGS>PATCHING>OVERVIEW
    PAGE or the PLAYER>MULTITRACK PAGE
    Hum.... why not simply use patching? Not clear to me neither...
