Home Soundcraft Forum Soundcraft Mixing Consoles
UI24r and Multitrack recording
Just recently got one of these machines and, apart from a few teething troubles (Actually headaches!) the only thing I can't do is record. It doesn't matter what I plug into the Record USB port, nothing is found. Manual says if the stick (medium) is to slow you will see the buffering change colour, and a message about the drive/stick/medium being too slow. Surely this means that it knows a Stick is inserted. The UI24 doesn't even show how much space is left. It just sits there and ignores it. Can someone please tell me what I am doing wrong. It can't do 2 track recording either as it doesn't appear to see any drive in the port. I've sent E-mails to tech support but have so far not had a reply (BOO HOO!) Please please please do not suggest the You-Tube videos. They only talk about Write Speeds. Thanks
  • Is your USB stick formatted to FAT32? If you’re not sure, plug it into your pc (if you’re using a pc), open file explorer and right click on it and select properties. That should tell you.
  • edited April 2019
    is it usb 2.0? Is it larger that 64gig? I can't get it to recognized usb 3.0, or a 128gig stick. that's all i know about it. The one i use it a pny 64gig rated at 10. which is about 20meg a second write speed.
  • Hoot,...
    have you tried calling them?
    https://www.soundcraft.com/en/support
    I realized Soundcard is owned by Harman...which is owned by Samsung...which does not have the best support reputation...
    This is one of my concerns.. (support if the product does not seem up to spec.) Have you solved your issue?
  • Hi,
    I let you know that I have the same problem with my USB 3 memory stick, on my UI24R.
    And everything works well with my old memory stick.
    It’s a shame because here is what we can read into the manual :
    « Multi-track USB Play- back will require a minimum of USB 3.0 with a transfer rate of 25mb/s. » :o
