Home Soundcraft Forum Soundcraft Mixing Consoles
error the digital signature of driver file "soundcraftusbaudio.sys is not accepted by this operating
hi everybody!
I got an Notepad-5 and and HP Pavillion x360 with Windows 10. I´ve tried so many times to install de USB Control Panel but it´s impossible!! I received the following message: error the digital signature of driver file "soundcraftusbaudio.sys is not accepted by this operating system¨¨
am I doing some wrong?
  • Hey mate! You're not doing anything wrong. I've got the same issue. The software developers responsible for the driver for this device clearly do not know how and why drivers need to be signed.
    In short, when a Company creates a Software product, it has to use a digital certificate, granted by a third party Certificate Authority to ensure a Customer that this Software is indeed provided by this Company and not SomeOtherCompany or a hacker pretending to be the Company to deliver a harmful software to you. Certificates are granted for no longer than 2 years usually and then need to be renewed. It looks like Soundcraft did not pay attention this time and the cert used to sign the driver is outdated, rendering this mixer pretty much useless for use with PC.
    You can disable driver certificate check deep in your computer settings (I've got through the process, and it is kinda involved, you'll have to have access to your BitLocker codes in your Microsoft account before you start) - it worked for me after I disabled the certificate check, but just today I found that it doesn't work again Soundcraft shows "not connected" so not the ideal solution, especially keeping in mind that you put your computer under risk disabling a security feature.
    So I'd suggest returning the device and getting another brand. Quite a shame, because the device itself is pretty neat (apart from not having a fcking 20 cent spent on a power button, doh!)
  • edited December 2018
    It's been 15 days since you posted, and it doesn't seem like there is an updated binary yet... Is there a good way to flag down the dev team to recompile their drivers with a new signature?
  • edited January 2019
    Hi, I had the same issue and I was able to solve it by disabling signed driver enforcement in windows 10. A quick google search will show you the steps to do so. I hope this helps.
  • I have considered doing that, but it is definitely NOT a good option. That is disabling one of the most important security settings on a Windows system.
    Hi, disabling signed driver is only temporary. You disable this function, install the unsigned driver, and after a restart, your windows 10 will go back to enable signed driver, so you'll be protected again. I am recommending this option because it worked for me. Good luck!
    Hey man, i PM’d you to ask for some details on your solution
  • 7 weeks ago I sucessfully installed drivers to make Notepad-5 work on a Win 10 laptop.
    This week, with a new laptop, I cannot get the drivers fully installed.
    It will allow me to playback, but no record input options.
    The graphic is a screengrab of the error message.
    "The digital signature of driver 'SoundcraftUSBAudio.sys is not accepted by this operating system."
    I'm running Win 10 Enterprise
  • I went back today to see if this has been addressed yet, but I still get the digital driver signature error with the latest drivers. This is a big black eye for Harman products, and I don't think I'll purchase anything from them again going forward.
