GNX4 vs GNX3000
Hi all,
Been gone a long time since I've been on here (a good few years), but I've kept up with the GNX3000. Lovely device, takes a lot of playing with (cos there is so much to play with!) to make good sounds, but it's great for the kind of prog and metal sounds I want.
I know it's long since discontinued, and possibly obsolete, but I recently remembered the GNX4. I couldn't afford it at the time, but time and the second-hand market have done their work. It's got a few more features over the 3k, such as greater autonomy with its onboard recorder, and I believe the footswitches can be programmed in stompbox mode?
On paper it does look like a superior device, but there is one glaring issue with the 3k, and that's the switchover time for patches in Patch mode - obviously an instant of silence is unacceptable when playing live. Does the 4 suffer the same issue? I remember reading a post years ago that mentioned a comparison but I can't find it.
Otherwise, has anyone switched from the 3K to the 4, and if so what are your impressions, better or showing up different issues?
Cheers,
Rob
Cheers,
Rob
Funny, I feel the same way about my GNX3
-Rf.
http://www.44lbs.net/ilia/compare_GNX.htm
I haven't kept up with all the firmware updates, but I believe it's still pretty accurate.
Great link, thanks.
I have firmware version 1.3 on my GNX4, is that the latest?
i own both and i have to say the sounds of gnx3k are way much better than gnx4..
infact i tryed to export the sound of gnx3k into the gnx4 but i couldnt cos te gnx4 have different dna sounds..
i will sell my gnx4 and buy a backu gnx3k for my gigs..
I've switched back to GNX4 about two years ago, after having using GNX3000 for many years prior, and I haven't regretted it. But I keep the 3000 ready to go as a backup at all times.
I was quite surprised by the numbers of users that complained about CA options. They were a little tricky to understand by the manual, but most on this board knew how to use them. One of the busier sections at my site was on control assigns and live usage which incorporated CA and SB mode.
