RP255 Pedal not working suddenly
hi
i don't know if this is right place to put this.
But, my RP255 Digitech Processor's pedal is no longer working.
It is not even 6 months since I bought it.l
I tried restoring S/W to an earlier version, but still it is of no use.
any clues ??
  • You have to be more specific.
    Not working - what does that mean? It won't turn on? Turns on, but goes into a strange mode? Turns on as expected, but makes no sound? Turns on and makes sound, but not the sound you're looking for (i.e. noise)?
    Suddenly - what does that mean? Did you drop it or hit it? Used it at a new venue or somebody else's house? Installed new software? Plugged something into it that's not a guitar? What is different from, or what happened since, it last worked properly, and how long ago was it? How did you use it when it did work?
    This could be a power problem, but you haven't specified where you're located and/or what kind of power supply you're using, or any other specifics pertinent to this.
    If the pedal does turn on but you don't get the sound you want, how is it connected? Headphones, XLR, 1/4\", USB? Did you test all the cables in the connection chain, including power cables?
    You also mentioned software/firmware update/rollback, but didn't mention version(s) or where you got it/them from.
    FYI, there are other forums on Digitech's web site specific to RP pedals - this is the one for 255: http://www.digitech.com/soundcomm/guitar_list_messages.asp?productid=255 but you will want to answer some of the questions above, regardless of where you post your inquiry.
