Can I use both pedal outputs at the same time?
I use a digitech bad monkey overdrive which has two outputs (amp + mixer).
while using the 'amp' output for the rest of the chain and finally - the amplifier, can i use the mixer output at the same time too for a tuner without affecting the sound that the 'amp' output is producing? I know that with the boss dd3, doing that will make the 'amp' output to produce only the delay sound, and the other output will deliver the guitar sound without the delay effect.
Thanks!
