HELP NEEDED again
hey there this is my first time using this forum and i would apreciate so much if you guys can help me .
i would like to know if you can help me on how to set up the s100 for proffessional compressing vocals???????
  • Same as any other compressor - set your threshold below peak, ratio somewhere between 2:1 and 3:1, attack to SLOW, and in the case of S100, delay to the minimal setting. Then adjust the gain setting until the output is peaking around -6 and -3.
    This is pretty general - the settings will vary somewhat, depending on specific setup.
