recording with the RP155
I finally figured how to record with the RP155, with no help from Digitech, mind you. Now this might not be the best or the right way, but I got it to work, and I'm done messing around with it.
I was finally able to use it with Audacity. I tried Kristal, but it kept locking up on me.
I tried countless settings just having the RP155 hooked up to the USB port, but to no avail. How I got it to work was with the addition of a small USB box that I had called a \"U-control UCA222\" made by Behringer. It's a USB audio interface with digital output, with 2 RCA input jacks & 2 output RCA jacks.
Then I have 2 RCA's from output of this box to the input of a home stereo unit.
I have a Y splitter (2 RCA to a female 1/4 jack) to the input of the Behringer box. Then I have the guitar plugged into the female jack.
Oh, and from the home stereo unit, I have a Y splitter, 2 RCA's to a 1/8th inch jack to the soundcard of the pc.
In Audacity, I have the recording setting set to Digitech rp155. And thats it. Barely any latency, sounds great.
If you know a better way, let me know.
But, I have a problem now. I've not used the RP or Kristal in about five months and when I wanted to use it again I could not record. Kristal did not connect to the driver. When I strum, the track sound bar moves but the program doesn't record anything.
I downloaded another program and I get the same result. Man, its So frustrating trying to record with the pedal .. and that's what I bought it for in the first place.
