Digitech GNX4 whammy question
Whenever I use the whammy on the GNX4 it doesn't seem to give that true whammy sound like the whammy of a single Digitech whammy pedal. For example when I want to play the whammy part of Satrani's song Searching, it doesn't sound good at all. Is there some kind of setting that I don't know that makes the whammy sound better?
Also I was wondering if there's a way to shut off the Wah effect when you press the expression pedal down because it's kind of annoying when you want to use the whammy effect and whenever you press the pedal down to hard the Wah effect turns on.
