RP150 confusion
I don't get this thing and the instructions don't make sense to me.
Couple of questions.
The Pedal only gives me access to the 30 Tone library.
How do I access The preset chanels.
I save my preset chanel in slot 1 of the user set, but I have no idea how to access it on the pedal. I must be missing something here.
Thks for any help
  • Could be something wrong with the pedal? If you just bought it, take it back.
    When I power mine up, it's in Performance Mode, and provides access to all the presets, with the up/down foot switches.
    (1-50) are the User presets. (51-00) are the Factory presets, which are the same as the User presets, but can not be changed.
    Knobs 1-4 give you Tone Library, Effects Library, Effects Level, and Master Level.
    Once you have a preset modified how you want it, press the Store button, and the current display number will flash.
    If you want to store it in no.1...use the foot switches up or down, until you get to that location...
    then you have to press the Store button again to save the changes.
