RP355 drivers downloaded and installed, Cubase working,no go
This is maddeing. I have everything installed on my PC and plugged in. I am running Vista home premium 64 bit version. The pedal has power. The USB from the RP355 to the computer, the guitar plugged into the RP355. All the latest updates from the Digitech web site. Everying is ready to go... and nothing. I have Cubase LE 4 open and still I hear no guitar. What am I not doing here? What's missing? HELP!
You have a setting, probably in Cubase, that is mis-set, so you aren't monitoring your git'r input.
Don't rule out demonic possession, either. :P
But lots of guys here do, and do well with it.
The thing I'm suggesting is something along the lines of selecting/deselecting what is being monitored...whatever section of Cubase your RP is running into isn't being passed on to the output part of Cubase; or else the Cubase isn't \"listening\" to the RP, so there's no input to monitor.
You're gonna haveta wait for one of these smartish guyz to chime in; I'm not much of a tech wiz. I'm just here to meet chix. 8)
By the way... I tried the most simple test you could think of, which is Window's built in sound recorder, while trying to adjust all the setting on the actual RP355... but nothing is getting through there. However, it will send audio to the RP355/amp just fine via USB.
johnmasterpiece, or gypsyblues73, were you guys able to get sound through your amps via USB?
When selecting your audio, you have to set the RP as the audio source in the track inspector.
IDK what the others found or didn't find to solve their issue. That's what's a bummer sometimes. They don't come back and say if the solutions posted remedy their problems.
