New RP1000 blowing my power amp tube!
<div style="displaynone">fiogf49gjkf0d</div>I just bought an RP1000 and have it hooked up via the 4 cable or Amp Loop method so I can place the effects either before or after my amp's preamp stage. This setup is RP1000 amp loop send to amp input, my amp loop send to RP1000 amp loop return, my amp loop return to RP1000 line out, my guitar to RP1000 input. My amp is a Peavey Ultra 112. As soon as I hook it up and power everything on, it blows one of my power amp tubes. I've verified my setup countless times. I thought I had a faulty tube, so I replaced it with a different pair of tubes. My amp worked fine with new tubes. Then I hooked the RP1000 up and the same thing happened. Anyone have any ideas as to what's going on here??
Um...what i mean to say is that i'm not much of a tech weenie. Other guys here do that; I'm just here to meet chix :roll: . So stay tuned, surely some of them there smartish guyz will chime in soon...
Guys? Help the brutha out? C'mon you tech wiz's. Wire this guy up; this'll only help so much:
For eveyone's reference, the set-up being discussed is the one shown on page 12 of the RP1000 manual.
The second thing I have seen on some amps are the fx loop shorting plugs on the jacks can go bad, or the internal solder connections fail. Typically you won't notice a problem until you use the loop. On other occasions if the loop jacks or contacts are bad (open during use), the amp may go into oscillation which can cause problems in the output tubes.
Seems to me you have the proper routing, just be sure you follow the details of using the amp mode properly via the RP1000. Other than that, it is possible to have a problematic connection or defect within the amp head. If the amp itself was not maintained and those jacks were seldom used, it's possible to have them inducing problems when in use. Try cleaning them with a good contact cleaner. Use only signal cables in your signal path, and be sure the speaker cab connection is a proper speaker type cable and not an instrument cable.
Just had a guy with a TSL head having problems with tubes red plating. He changed tubes and other things. Turned out the 16 ohm amp output jack connector for the speaker cab was defective (intermittent). If he had been using an 8 ohm cab, he never would have noticed the problem. We were lucky enough to verify both 16 and 8 Ohm jacks operation and determine what impedance he was using... if not, that may have been back in for repairs.
