X-Edit - how to swap two patchs in user bank?
Hi, I have X-Edit 2.4.1.2 which I use for edit my RP350. I have tried to find the way of swap (interchange their positions in the user bank) two patchs with this program without have to save both to hard disk then copy, then delete then reload ....annoying huh? I mean, does X-Edit include some command or menu for make that ?? I really can´t believe any decent editor, even free, doesn´t have such basic, simple and so necessary functionality . I beg God I am being blind and not seen that.
cheers
Post update EDIT: after download X-Edit v.2.6. and realize not swap command was added, I figure out a method for swap patchs. it did work.
Supposing for example you want swap patchs 40 y 50
1- copy patch 50 (the order is not relevant) this will hold the patch in clipboard ram.
2- Shitf+drag patch 40 over 50, this will duplicate patch 40 in 50 position
3- highlight patch 40 and right click/paste . This will return back your patch 50 from clipboard.
4- that is all ...swaping done.
cheers
