Digitech RP250 Whammy/Wah
I have question..
So, here it is..
I was wondering is there any way to turn of the activation wah/wah when I press the expression pedal down?
Example, I play Killing in the name of - whammy solo, 2 oct. up, and when I push pedal down for the highest pitch, many times I turn on wah, so that's the problem, how can I disable activation of wah/wah?
P.S. I tried to write this in the best way I can, so have mercy for my english, it's not my mother tongue, I hope you'll understand what I try to say. :)
  • Hey, i know you posted this about 5 months ago, but here's an early christmas present for you if you never figured out the solution to your problem.
    1) Hold down both the up/down buttons, the same way you would to open the tuner. Don't release them.
    2) The screen will display in this order: Bypass, Tuner, Exit,
    , PDLCAL
    3) Once it displays this, you can calibrate your pedal.
    i) Toe Dn - Put the foot pedal all the way down, and press up/down.
    ii) Toe Up - Self explanatory. Put your toe all the way up, press the up/down button.
    iii) VSW - *THIS IS THE IMPORTANT STEP!!! Adjust the VSW by pressing the up/down pedals. This will change the threshold for activating wah. I believe if you make the number higher, you have to press harder to activate it (I could be wrong). You can test it by increasing or decreasing the number to your liking, then activating/deactivating wah.
