U2
has anyone made any presets for U2's delay?
ive got a couple for where the streets have no name but i cant find or make one myself for still havent found what im looking for.
anyone help?
  • Click on the GNX-4 icon at the top of the page, when that page opens scroll down to patches and open them, then in the upper left corner type in U2 in the community search box. Select the u2 patch by G3456, his are usually pretty good.
    peace
  • thanks!
    i downloaded severeal form the gnx4 forums. i have a 3000. will these patches still work? im new to the whole workstation thing
    thanks!
  • No, they are not compat since the 3k hardware is completely different.
    Edge sound is more about his delays and his picking of notes in between delay. Start with a simple clean amp or Dirty Vox amp and set delay at about 410-420 msec.
    If you want a wider sounding delay, select Spread Delay at those times and increase the spread amount (width) for a more drastic effect. Adjust delay level to taste.
    Operating in Stompbox mode, you can also add a Screamer for a little more overdrive or use the Sparkledrive. Limit the gain of the stompbox so not to saturate as much.
    If you want to get fancy, Go to your expression assigns and adjust a range for the delay level, dist level, and maybe add compression if you want.
