RP350 problems....help!!!!!!!!!!!!!!!!!
hello people,i lately have d/loaded the USB drivers,the X-Edit and the documentation i needed to edit my RP350 with my computer.But after instalation i'm havin' a lot of problems!!! First it was working and i could hear and edit new sounds on the RP350 with the computer but suddenly it stopped working.I can't hear any sounds and...above all...it seems that my computer now can't recognize the audio-card!!! I can't listen to the music,i can't hear the sounds of the OS,my computer is MUTE!!! and it is having consequences on my MSN,because it keeps saying there are problems since i've installed the X-EDIT stuff and USB drivers.....Please Please....if anyone had the same problem...or do know a solution....reply then!!!
my OS is a WINDOWS XP
thanx for reading
MaKs (guitarist of The strip in midi side)
  • Mmm... It seems that your computer took your RP350 as the default audio in/out, so you can do 2 things:
    1- Go to the audio device manager in your computer and select its sound card as the default audio in/out device. Or..
    2- In the same audio device manager, select the RP350 as the default audio in/out device, but conect your speakers to the output on the RP350, so you'll be able to listen to your RP and the computer sounds through them.
    I assume that you have conected the RP via USB to your computer.
    Another option I use is: in the same audio manager on the computer, select the RP as your default audio input device and the computer sound card as your default output device, this option works good for me when I'm recording.
    I hope this could help
    Take care, have patience and have fun!
