Supermodels for GNX 3000
I need to know if g3456 Supermodels is compatible with Windows 2000 and/or XP? thanks!
  • They're X-Edit files. So as long as you can open X-Edit, you can access
    the files. Which is not a problem with XP. Haven't any experience with
    2000. Maybe someone else has tried X-Edit with 2000.
  • I believe X-Edit requires XP.
    PC Minimum System Requirements
    Windows® XP (SP 2 installed, .NET Framework 2.0* installed)
    500 MHz processor speed (1.2 GHz recommended)
    512MB RAM (1GB recommended)
    *.NET 2.0 will be downloaded and installed during installation of X-Edit 2 software if required. .NET 2.0 can also be downloaded from Microsoft’s web site
