Clean Smooth Guitar
I have just had the GNX3 for several weeks. I play through a Fender Strat and a Dean Acoustic Electric, but can't get a clean sound. I am looking for a smooth, soft sounding guitar, but end up being muffled or too crisp sounding. Too twangy vs. soft. Any ideas about presets or configurations I can try?
An idea is begin with a preset from factory. Take the \"Tween preset\" -for instance-, and go to genEdit to change equalization. If you think that sounds too trebly, try slowing presence or treble amount.
Another thing is to know what amplifier and how are you connected. Its not convenient plug in your gnx on front due to this one have a pre-amplifier.
Please, tellme about your rig and after I may be able to help you.
http://gnx3faq.loon.com/EVB_Get_Started.html
It just gives you a quick way to switch between 2 amp sounds. Most real amps have a \"clean\" channel and a \"dirty\" channel, and the Red/Green thing is supposed to be like that. But unlike a real amp, you can set your GNX amp channels to anything you like, even different amp models, so that you can easily jump between 2 completely different amp sounds.
In stompbox mode (the Up and Down LEDs will be yellow), foot switch 2 (labeled AMP) toggles from red amp to green amp (or red to green to warp).
In \"bank\" mode (up and down LEDs will be green), each of the 5 footswitches will take you to one of the 5 presets in the selected bank.
-Rf.
