Backing up all the User presets at once?
Is it possible to back up all the User presets at once, like to the compact flash? By this I mean saving all the presets I've created or downloaded from the web, all at the same time instead of saving them to the card one at a time using the \"SAVE\" button on the GNX4 control panel.
I might need to do a factory reset to my GNX4 and wanted to back up the presets I have in place. I connected the GNX4 to my computer and then in X-Edit I opened the User library, and chose Device/Backup. This created a .g4a file.
Does this file have the user presets on it? If so how do I access those? I tried opening that file through X-Edit and it just gives an error message (\"Document file type is not recognized\"). Opening it through Notepad or text yields garbled fonts and symbols.
Thanks for your help!
grell6954
grell6954
I think I did use the backup function, I'm just not sure how to use the resulting file that was created. Can you explain how I could use the .g4a file that was created to 'get back' the presets I've created if I do a factory reset on the GNX4?
Does this .g4a file have the user presets on it? I'm not sure how to access those. I tried opening that file through X-Edit and it just gives an error message (\"Document file type is not recognized\"). Opening it through Notepad or text yields garbled fonts and symbols.
Thanks again!
Grell6954
As far as WHAT it backs up - I'm pretty sure it's the entire unit, Factory/user/card. But I won't bet my life on it; use XEdit's help file, it should say. Or ask someone who's smart.
I think you want to make the .g4a file, and then extract each and every single preset from that, and put them into a folder on your computer if im not mistaken. I don't think thats possible but I think I understand what your getting at by doing this: a huge time saving technique.
As for now, all I can think of (unfortunatly), is to open each preset in X-Edit that you want the .g4p file for, and save, not store, to your computer. Yes. Each and every one.
I think what your doing is pointless. Hence the technique that is given to you to do it. I might be wrong tho. You don't need every single preset file thats already on your GNX. If you do, then back it up andf restore it when you change things wayy too much and liked it more at the time you last restored it.
I could be totally misunderstanding the question here, but I think not.
I had backed those presets up a few days before, and just in case I had misunderstood the process, I also went through and saved about 20 presets individually. But the restore function did it all at once so I didn't need the individually saved ones.
Thanks for everyone's input!
Now that I've done this I have to try to figure out why, even after the factory reset, the GNX4 doesn't seem to go into record mode anymore, or even recognize the compact disk in the reader. I've also tried new, different disks, and the GNX4 doesn't even ask about formatting the new one. See my next question post in this discussion forum for more on this problem.
