Speaker wiring/impedance issues - experts needed!!!
calling all tech weenies and other smart expert guy types...
OK. I wired up a bass cab with four 8-ohm speakers, using standard series/parallel wiring, in order to have the cab end up with an 8-ohm load, which the amp that runs it requires.
After finishing, checking my wiring accuracy and quality of the solder joints, I put a normal ohm-meter on it, and it measured 43 ohms!!
At this point I crapped my shorts and panicked...then I went online to look up different wiring sites and so on...all the series/parallel wiring diagrams were the same, but one site (written by an IT guy/systems engineer) wrote of the difference between \"impedance\" and \"resistance\", and that any speaker coil will vary in impedance throughout it's freq'y response, and that a normal ohm-meter can give a widely varying ohm reading.
SOOOO...what I want to know from all youse smart guys is: does this odd ohm-reading mean something is messed up? Will it blow my amp, or run at 4-1/2 watts 'cuz the impedance is too high? Or is this normal???
For once, I have no idea what's up with this thing. Please help!
I have no idea what the problem is here. I guess I would start by measuring the speaker terminals alone. See if you get 8 ohms on all of them, if not and they are all \"wrong\" by the same amount I would be thinking you have a problem with the multi-meter.
HTH
So...I'm tyring o find out if there's something actually wrong, if anyone's ever had something like this come up. I need opinions from all you engineering experts.
And all you other guys - take a plain ol' ohm-meter and measure your cabs. Are you getting a nice even 8, or 4, or whatever ohms? Or some other kinda reading/s? Check in, you guys.
My cabs are pretty much spot on +- 0.5 ohm
Turns out the REAL problem wasn't
my wiring my solder joints either of my multimeters the wiring diagram/layout I used. [/list:u]
DRUM ROLL PLEASE...the problem turned out to be the GARBAGE 1/4\" in/out jacks this cab was built with. (the kind that switch open/closed when a plug is inserted). Once I bypassed them and checked impedance (with both multimeters) directly at the wiring, they came out a moderately close 5.9-6.3 ohms. So I'm going to replace them with some good quality ones...even if I haveta order them online (I doubt Radio Shack - the ONLY electronics supplier in my little town, has anything any better.)Anyone wanna help me with my laundry? :shock: :shock:
MEANWHILE - on to a new crisis. I've started a new thread for this one. It's an even STUPIDER problem than this one, 'cuz I caused it myself :oops: :oops: ...please check it out, and advise...
