Proper way to hook GNX4 to church audio board?
Guys, I am sure the answer has been said here many times, and I've read through several posts here to try to get an answer, to no avail.
Anyone care to help a brother out?
I'm playing a PRS with tone and volume at 10 into my guitar input. Output is XLR into a DA set to line level, then running into an audio board, supposedly with the gain set to line level in.
Well, the complaints I get from the audio guys is that my audio level is low and yet horribly overmodulated. Naturally, I'm getting the age-old \"sounds great in my headphones but lousy output to everything else\" syndrome.
I'm also going to a powered speaker for my monitor and both the XLR and 1/4\" TRS are set to halfway or 12 o'clock on the GNX4. I get the same thing on the powered speaker... low levels but overmodulated.
I guess my next plan of attack is to try to go directly into a small audio board so I set my output levels from the GNX4, or record and bring into Audition to get a visual on what I'm hearing.
Any input from anyone here doing my kind of setup would be greatly appreciated.
I've read through guitar3456's posts but am wondering what to do for a guy who uses the GNX4 almost entirely live into an audio board, then to our amps and main speakers. :oops:
P.S. Make sure Speaker comp is on pushed in. I always leave mine on seems to work better for me that way?
I've had speaker comp OFF... I'll try that as well.
Where do you have your output level set to (the XLR out)?
Maybe as a side issue, do you ever use the acoustic effect #51? It sounds absolutely terrible on my GNX4... I've tried two different guitars and I get a ton of line noise hiss that the gate cuts off when I don't play, but is really loud and annoying when I do. I sent my GNX4 in to have some stuff fixed by the Digitech tech support and they said after replacing a bad IC chip, everything checked out fine. Does anyone get a clean sound from their GNX4 when using that effect?
Right there with you on Jesus is the Rock!
Scott
Rock on like it says in
Psalm 33
Now to see how things go this Sunday with bypassing the DI.
As an aside, for you worship players, what presets do you like to use, either default or ones you've downloaded?
I think the GNX series are great for worship guitarists because you can get so many tones out of them for all types of songs and situations. I really like mine, and I have passed the word to our band, so now the other guitarists also play a GNX4 and an RP200.
Now if DigiTech would just get those Vista drivers out... ;-)
Scott
Sure wish I had a personal ear monitor, though.
Anyway... thanks, everyone. You were all a big help!
CK it out
paul
