Expression pedal settings ??
A question about any GNX. As I read through the manuals for all GNX, I find the same default for the expression pedal. Assign 3 parameters to it and V-switch to the Wah.
Is there a way to disable the wah so when you turn off your assigned FX you go to nothing? Or is there a way to set the wah to be off so it doesnt come into play?
I'm used to Boss GT boards which allow you to assign up to 10 parameters on up to 4 different physical controllers at the same time mind you, and the default off settings are always nothing/0. Theres got to be a way to get nothing. I remember some discussion about it at one time but can't find the right search.
http://www.guitarworkstation.com/forum/viewtopic.php?t=963
