Home DigiTech Forum GNX Forum Achive GENERAL Member Patch Review
Synth/Electro Sound
Does anyone have a synthy sounding guitar patch or a guitar patch that sounds electro like? I've been playing around with the envelope filter but i just can't get a good enough sound. If you have a patch can you either upload it onto the sound comm or send it to me please :). Thanks in advance
  • http://www.digitech.com/soundcomm/guitar_view_patch.asp?productid=199&patch_id=10440
    I made that one a while back. Its envelope filter based, so it might not be what you want.
  • You can do this with several things:
    * Envelope filter (as phil did)
    * Synth Talk
    * Ya-Ya
    * Wah (full range)
    The first two will be based on how loudly you pick. If you make settings for attack and sensitivity correctly, you'll be able to trigger a synth-like effect by picking harder. Ya-Ya will be based either on expression pedal or LFO (or with Auto Ya). It's less synth-like. Full-range wah is almost exactly like an envelope filter but gives you considerably more control - you will also trigger how it sounds with either expression pedal or an LFO.
    You could also get creative and assign a parameter such as sensitivity to the expression pedal. This way you can decide when you want the synth effect and when you don't. You might also consider using a pluck gate to create smoother synth-like effects, with either envelope filter or synth talk (keeping in mind the attack parameter on the effect itself).
  • Thanks for the tips and patch, unfortunatly the patch isn't quite what im looking for, what I'm looking for is like a more electronic sound if you know what I mean? I shall try playing around with the envelope filter and synth talk and the other stuff when I next have some spare time.
  • sounds like you want a ring modulator like effect...
    Have you tried playing with the \"garble\" audio filter in Pro Tracks?
  • Never even heard of it, what is it?
