SM57 vs SM58
I was wondering, I know the SM57 is used mostly for guitars. What would be the difference in recording with a 57 and a 58?I read that the 57 has a range of 40 -15,000 and a 58 has 50 - 15,000. But does that really make that much difference when recording? Or is there something else in the mics that make a difference?
It is true the SM57 and SM58 microphones are based on the same cartridge design. The main difference between them is in the grille design. The SM58 was designed for vocal application and it uses a separate grille with a very effective pop filter. The SM57 was designed as an instrument microphone where smaller grille size is preferred. In this application the pop and wind are not usually a concern. The SM57 uses an integral resonator/grille assembly, where grille is actually a part of the cartridge. These two grille designs place the diaphragm of the microphones in a different acoustical environment. First of all, the distance from the top of the grille to the diaphragm is significantly shorter on the SM57 compared to that of the SM58. This allows for closer sound pickup with even more pronounced proximity effect. Secondly, a different resonator/grille assembly design of the SM57 is responsible for its slightly higher output above 5 kHz.
M.M.
