Windows Media 9 or 10 / Setting Sound Levels
Trying to set my sound levels again on the GNX3... :?
Anyone know if you have to plug in to the computer's mic input to effectively use the RTA? Better yet, can some share if you have effectively used this feature and how.
Thanks...
Thanks...
http://www.softplatz.com/freeware/spectrum-analyzer/
The peak meters are pretty accurate in this. You can have it run via a mic or line input through your pc. You can also mic your amp and go that route but be cautious of mic placement variables in distance, and angle. So long as you don't move anything your levels should be respective to eachother.
