RP 150 PEDAL
I have a RP150 and have installed all drivers. Pedal seems to have frozen now and wont do anything. It has a 5 in the led box and nothing works?? Any ideas??
  • I just got a 250(same kinda pedal) does it boot up with that stuck on five even after you unplug and reboot the pedal?
    I needed to install 3 things from the digitech websight for exedit 2 to work.
    The usb driver first
    Then the RP updater (my pedal wasnt ver 1.7) If your RP250 hardware displays VER 1.6 or earlier, you need to download and run the RP Updater file to update your firmware If your RP250 displays 1.7 or later, you do not need to download the RP Updater.
    and finally the xedit 2 software.
    make sure your pedal wasnt plugged into the usb BEFORE it was supposed to be. a screen tells you when to plug it in.
    If that doesnt work I would unistall and reinstall the software making sure to follow the order 0f the install instructon carefully.
    let us know how it works out. you'll love the new xedit its da bomb!
  • My RP150 was frozen at 12 position, and I can't do anything with it...
    Please someone help me... :(
  • Did you do a factory reset? This MUST be done after the upgrade or the unit will fail. Read the back of the instructions for details on how to reset.
