Fender Princeton Chorus. Need Advice
My local music shop has one, used. It is in great shape. I thought it was new at first. But they took it in on trade. Everything works perfectly and it is set up perfect for my GNX3000.
Two inputs
Stereo Inputs
Effects Loop
Clean and Overdrive channels..
2 Speakers 10\" Fenders..
Solid State..
I figure this would be a great amp for my GNX3000. Anyone have one that they are using. Am I correct in assuming that this amp would be great to use with my GNX3K?
Also, they are asking $275.00. The price seems to be about righte from what I can tell on ebay and harmony central...
Here's one that is selling new on ebay...
ebay item link
Two inputs
Stereo Inputs
Effects Loop
Solid State..
ebay item link
I went ahead and put the amp in layaway at the music store. I am pretty excited about bring it home in the next month or so.
So when I plug into the stereo input of the amp, what is exactly going to control the volume levels of amp?
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Princeton_Chorus.pdf
Personally, I see no point in running a stereo signal if you have a single amp. Even if you do make use of the stereo effects, they will not be nearly as clear as two speakers on either side of your performing area (stage, band room, etc). Better set your GNX to mono, plug into the power amp in on your Fender (mono FX return in this case), and wail. My opinion, of course.
the input side of the amp is mono> mono split> then to stereo efx and ampliflers (individual) and speakers.
If you set your GNX so the Chorus is off on your live patches, going through the input (hi impedance) will serve the unit in it's design. The separation you wish to have would be greatly enhanced this way.
Use lower gains, NO chourus (although you could use phase or flange) since you already have a good stereo chorus built in.
Set your patch delays to MONO.. doing this will enable you to use the amp to it's fullest potential since the signal would be mono as required. The amp will take care of the multiplexing and stereo sep for you.. Best yet, it leaves you another R ch out for additional amplification to a board, powered monitor, etc.
