Home DigiTech Forum GNX Forum Achive GENERAL Member Music Review
Abide In Me Final Mix
All,
I know this has been a dead horse kind of song with many takes, Remixes, now some eq'ing. I decided to work on this some to day and finally finish it with some last listen sugestions by AC & Mark007. So here it is check it out. I think it's finaly done!! 1st one.
God bless you All!!
Thanks for checking my tunes out and commenting!! I appreciate everyones feedback & comments I do try to learn & grow from them as all this is still very new to me.
Partch
http://www.digitech.com/soundcomm/guitar_view_music.asp?productid=199&music_id=2557
  • Congratulations on finishing your first tune, but if you're like me, it's only temporarily finished. In time, you'll want to touch things up, add instruments, change some lines... :lol: Great job buddy! I hope to hear more.
  • Hey thanks AC!! I would be interested to see what Mark thinks of this now?? I tried only to do the things he suggested, in this final mix. I think I spent like 15min or something finishing it up with those last little tweaks.
    By the way it's great being able to EQ now!! I did have to spend 60 dollars for the VST adaptor for Pro Tracks but it was worth it!! Now I can use several free EQ plugins. All yeah I've learned as well from playing with Jamstix that you can add the effects & such in the effects bin and hear the imidiate changes etc.. Brilliant!! I used to process the track from the menu so no changes would be heard till it processed the whole track. Kind of dumb I thought? Well I was the Dummy now it works just like I would anticipate from the effects bin. Just awsome!!
    God Bless Ac!!
    Partch
  • Great to hear buddy! You're gonna start having some fun now. :lol:
    As far as effects go, be careful with them. You don't want to add reverb to drums. Just set Jamstix to have the drums dry and record all of your tracks that way.
    You want to add reverb when you master all of your tracks. Basically insert the reverb into the master bus. This way, your mix will make sense. Otherwise, it'll sound like your drums are in another room along with the other instruments possible having unbalance reverb also.
  • Partch, Hey bud you did a fine job! That sounds much better.
  • AC-Thanks!! Yes I totaly agree, that basically EQ should only be done at track level. I have only ever added slight Ambience to the whole mix as to finish it, never at track level.
    Mark-Hey thanks bud!! I thought you would like this one better!! This tune came along way!! And for were I'm at right now in my experince and Wisdom in this stuff I'm happy with it!! Praise the Lord for a fairly good Recording!!
    God Bless you Guys!!
    Partch
