MIDI won't play on GNX4
I created a drum track with Protracks and saved it to my cf card the way
the tutorial said. The file shows up on the card. I turn off the cf stor, try
to play it and nothing. An mp3 right next to it plays fine.
With the cf stor on, I click the file and it plays on windows media (as a
keyboard).
I'm using the GNX4Completedrums drum map.
Any idea what I'm doing wrong?
keyboard).
Go into the PTP midi window and select the output channel to Midi Ch 10 (click for dropdown expansion window)
Normally the drum map is default to the appropriate channel. be sure when you \" save as\" to the GNX CFcard, you save with .mid extension.
Rockdrum1.mid
save as Midi Type 0
Playback via GNX4 drum mach. Advance your drums via the dial wheel. You should see your drum files after the metronome. Select using the drum machine transport.
don't forget that using the Midi file with the GNX drum mach gives you access to all the kits, and you can change them as desired.
thanks for your help.
