gnx4 recording output, i cant get one thing
how can i do to make the gnx4 recorder sound actually as if the signal from the 1-4¨output but with the mixer,PA button speaker compensation
i have a different sound in my output 1-4¨ with the speaker compensation button enabled,that with the recorder..why¿..is any way to get both sounds the same way...as it sounds with button enabled?...thanks
  • Just keep it enabled all the time. If you're running to an amp, that's probably what is changing your sound - not the GNX.
  • ok..i have one sound with the speaker compensation button enabled, and then when i record something with my guitar..the sound in my recorder its very trebly..with lots of highs..because the button doesnt affects the recorder..and thats bad ,because i like it with the button enabled..so if someone know how to make the recorder and the output 1/4 as if the button was enabled all the times so both would sound the same please tell me, ....less treble..please help....thanks
  • turn all speaker compensation buttons to on, then leave them that way...... SECOND, your recording tone and your LIVE tone are going to be different as it is two seperate things.......most recording tones sound nasty live but HUGE recorded and most LIVE tones sound HUGE live ,but, scrawny and whimpy recorded
