Which amp ?????
I am looking to buy an amp, either a Fender Hot Rod Deluxe, or a Mesa Boogie of roughly the same size/caliber (I know that they are totally different amps but I haven't decided on which one yet). I plan to use it a majority of time without the GNX3 pedal as I have powered monitors that I run the pedal through now (at home).
Does anyone have any comments or experience about using either amp with a GNX3 pedal. I obviously want as little colouration of sound when using the pedal. I assume that I would be using the pedal through the amps effects loop.
Thanks in advance,
Dman
Thanks in advance,
Dman
And another guitarist I've played with used the Deville, with 2- 12 inch speakers at 65 watts, I think. Very nice amp!
Desertbluesman always said if he was going to plug his GNX-2 into the regular input he would max mids and turn back the bass and treble. He said that was \"neutral\" for the HRD.
You might go to the GNX-2 forum and see if he is still around, he was always willing to share his knowledge.
HTH some.
... although Harv (as did I) picked up an Epiphone Valve Junior Head for $100 and both of us marvel at the stellar tone that little guy produces!!!
