Power Amp Trouble
A couple of days ago a fuse blew on my mesa 50:50 power amp...after replacing the fuse, i noticed that the 4th power tube did not light up anymore,after checking it it looks like it blew..the silver film on the top of the tube looks like it burned out.....Can the amp run on 3 tubes??? what could happen in this situation? also, would it be better to just buy the replacement tube or is replacing all 4 tubes better??
If a vaccum is lost on a tube the silver dot you see will be white. If it's blowing fuses you have either a bad tube or a power supply problem in the unit. What you can do, pull the tubes out and turn it on. If it blows the fuse you have additional power supply probs. If not, order yourself a Quad of tubes. Some models used 6L6, some used EL34's.
I suggest JJ's or Svetlena brands. EH are not bad, but can become microphonic with physical shock and vibrations. Don't buy Groove Tubes..just a suggestion. The luck on those are pardon the pun..50/50.
These are in pairs which is fine since you have 2 pairs for each channel.
http://thetubestore.com/teslael34l.html
http://thetubestore.com/ne-6l6gc.html
