guitar 3456's supermodels, these are a MUST HAVE!
I just got 3456's supermodel collection in today. In my early examination I found his product was very easy to implement and I learned a great deal about the GNX4 and Xedit as well. Thank for that 3456!
But that's just the beginning. These models are so much like the real thing I just can't believe how good they sound!!! One hell of a good job there 3456!
If you are new to this forum and haven't checked them out yet I strongly suggest you do so. I could have worked for days and not come up with even one patch that sounded so good. In this case you get a full library. Make room on your preset list. Those bothersome factory presets are a thing of the past now. GET READY TO ROCK!
http://www.mtprosound.com/MTPROPAGE1/Links.html
I'm fairly certain there's a bunch there for you to check out as well.
Hope that helps.
Read the documentation, apply some of the new models, tweak and enjoy. There is so much on that disk it would take a long time to audition all of it. I've also learned a great deal about tweaking some of my patches and using (understanding) the GNX in general.
The more time I spend working with this unit the more it delivers.
I'm certainly not the most experienced voice on the forum (there is a lot to learn just reading past posts). but if there is any way I can help, let me know.
Tinny and fuzzy, sounds like you had Speaker compensation off...
Tinny and fuzzy, sounds like you had Speaker compensation off...[/quote]
That is because I was playing through a power amp into a 12\" speaker. The XLR out has SC on but the SC should be off in the 1/4 out into a power amp and speaker cab.
The GNX is a Model of a working amp. Add that to a Guitar Amp and the sound is colored. Hence you will have to have different settings when using your guitar amp..ie gain lower on amp models (I think it gives the amp more room to do it's job) EQ changes, and cabinet tuning to counter the speaker coloration.
What you hear from headphones or on recordings with the GNX is Full Range signal unaffected by any coloring of any amp or speaker system. Eminence Modeling 12's are as transparent as any guitar speaker you can find.
Speaker compensation off = Appears to be a 20dB shelf EQ with corner freq. 7.5Khz...in other words not flat from GNX, sometimes sounds good with some guitar amps/cabinets
I didn't like the brand of amps I thought I would have initially and leaned more toward Amps I would have never guessed I'd like
Yeah, factory presets are fuzzier than the super models. The super models are \"tighter\" and \"clearer\"
From the top of my mind the Plexi Drv is a very dynamic bluesy tone with the volume rolled down.
Stevey Ray patches, Gilmour also give me that \"clean\" distortion... Also plexi comp that's another one...
when I had my gnx3 I barely messed w/ it at all---but with the gnx4 and supermodels I'm makin patches and adjusting stuff all day long and having a great time. Next I'm gonna start using banks instead of just stompbox for live use.
thanx for the disc 3456
p
And you where worried to shell out the money *snicker*
Don't overlook the Hi Watt selections. \"Top Lead\" is screamin' A lot of drive and a crisp crunch. Huge amounts of sound!
