GNX3/4/3K w/ external Expression Pedal??
OK - I'd like to add a second MIDI expression pedal to control another parameter on my GNX pedal. I prefer something small like the M-Audio
EX-P. The way this pedal is wired it provides a continuous voltage range output on a TRS 1/4\" jack. There should be some simple circuit to change this over to the 5 pin DIN standard MIDI jack? Anyone here ever done it or know what you need to do (not afraid to break out the soldering iron).
Also - not sure how you assign an ID to the expression pedal, i.e. I know that MIDI allows for multiple \"continuous\" controller pedals but doesn't there need to be a specific MIDI ID so the control voltage is assigned to the correct MIDI parameter.
Thanks for any help.
