Board clipping
What does board clipping mean. I noticed it on one of my patches
'the red led between user and factory\" lights up only when I play heavy rhythm is this bad?
Sorry it's alittle vague.
STEP BACK! IT\"S GONNA BLOW!
lol
Maybe guitar3456 can weigh in on this. I would like to know just how far I can push this GNX with out blowing it .
Thanks .
\"Forever love it loud\" B L S.
COMBODRIVE.
Some of my early recordings I purposely set the gains to turn on the red LED on loud output portions of a solo..
I was thinking that Red LED corresponded to the red on a VU meter which when I used to record on a reel to reel would set up my input gain to just barely touch the red with the VU needle on loud output portions of a solo or for anything else..
The red LED on the GNX definitely indicates an overdrive (CLIP) situation.
Not just a mere indication that you're approaching a clipping situation..
Learned the hard way..
Thought I'd pass it on...
2-3 LEDS lit= good patch tone...above that (depends on the patch) BAD!
COMBODRIVE.
Saved the patch that I like so much. and didn't blow the GNX.
COMBODRIVE.
Headroom experienced a paradigm switch!?! :shock:
Red light = too late to fix in the mix. You can bump the gain on a good signal in the mix, but if it clips you're kind of stuck with it. A little clipping isn't always bad, it sometimes defines a heavily distorted tone. In that case I often use a compressor on the track to even out the signal and bump the gain. The draw-back can be loss of dynamics from the compression.
If a whole track clipped you're really kind of screwed. If it is just a small spike here and there, it usually can be dealt with. A compressor helps here too. If I were using software, I might split the section out and use an envelope to lower the gain a little.
My best advice is to record at your best levels. You'll maintain all the dynamics of the passage and better reproduce that outstanding patch/amp/guitar tone on yout tracks.
But what do I know?
Combodrive started out talking about \"board clipping\" and \"the red led between user and factory\"... You mean in the Preset Bank area? I don't see such a thing on my GNX4, nor can I find anything in the manual about this. The thread started out talking about generic patch levels, but then it seemed to morph into std. discussion of clipping as monitored by the record and playback level LEDs in the Recorder section, which I understand.
Experimenting, I took a couple of my most powerful patches and cranked their levels to the max and wailed on the ax. I saw no red LED flash between user and factory. I also was always able to lower REC/playback LEDs to 1 or 2 green LEDs regardless of patch \"strength\" by lowering USB 1-2 LVL.
So I guess my question is, \"Is there such a thing as a patch level just being too high causing clipping independently of what's measured in the record/playback LEDs... and if so, how is this detected?
Thanks! - g
