can someone check this for me
I am not at home, but need quick answer for amp purchase:
When using GNX unit with CD input for backing track/jam along, the output goes clean through the output (uncolored or affected by effects/amp modeling).
Question is in BYPASS mode. Is the CD/Jam Along signal sent out to outputs even when in bypass mode? I can't remember, but I want to see if I can use the jam along features of GNX but bypass the amp models and affects.
By the way, I have a GNX3...but I think behavior is same on GNX3-4-3K. I want to run the jam along signal through GNX, but bypass effect/models and output to Vox AD30VT and use its amp models.
thanks!
thanks!
