HELP
Hi dudes,
My problem is this, I have created a new user preset using the warp function on the GNX4, on channel 1 I have a clean sound and on channel 2 I have used the same amp & cab but increased the gain to get some crunch. What I want to do now is add some chorus to channel 1 only and a little delay/reverb to channel 2 only so that I only have the chorus on channel 1 and the delay/reverb on channel 2. Can anyone explain in simple terms how I can do this or at least point me in the right direction?
TY
Shando
  • You can always make 2 copies of the same preset and save them back to back. One saved clean w/chorus ready to go the other crunch w/reverb. The big drag is over shooting your preset and landing on something unexpected. There might be a fraction of a skosh of delay switching, but still quicker than chorus off, switch amp channel, delay on, reverb on.
  • Yes, I see what you mean. In fact that looks a lot easier. However, Is it possible to create a preset which I can switch between 2 channels that say have chorus & reverb on channel 1 and no chorus or reverb but distortion & delay on channel two, switchable between the two via the expression pedal? This would enable me to use the two different tones in one preset whilst using the recorder also.
    TY
    shando
  • Shando,
    Absolutely! Set your Delay on and tweak the effect. Assign the level to EXP 1. The minimum setting will be at 100% and the Max will be 0. Do the same thing to the Chorus with EXP 2, only the Minimum will be 0 and the Max will be 100%. That will get you started. You can always tweak the Min and Max settings to taste. (min 0--max 70% etc.)
    HTH
  • Excellent! I will give this a try when I get home.
    TVM
    shando
