on the green channel, dial in the rectifier amp plus any cab that sounds good with.. use ur ear.. on the red channel, you may use the rectifier once again or any other amp models that can enhance the rectifier sound.. such as britcmbo (it's a Vox Ac30 clean sound), then warp it to fully to the green... then start tweaking.. push the button to access the green channel amp setting... same with the red channel.. generally I start with gain setting at around 75 and level at 70 .. bass, mid, treble are up to ur tatste..
