change the drum tempo in same song?
is it possible on a gnx3 to have two different tempos in one song?
or do u have to make a backing track on the pc?
  • If you construct the midi in PTP, you can use Tempo View to make per-beat adjustments or draw tempo 'envelopes'. You should then be able to download the .mid into your gnx3k. Works on my gnx4.
    - g
    Oops... I see you said 'gnx3', not 3k. Don't know, mate... sorry.
