Sonar Projects with WDM & ASIO drivers
I been using WDM drivers for my SB Platinum, and tried switching to the ASIO drivers which worked fine when creating a new project. I have found a strange problem when opening projects that were recorded using WDM. It seems to load fine, but when I press the play button, nothing plays. It looks like it's working, but no sound.
As a test, I went back to the WDM drivers, and the same thing happened when opening projects that were recorded in ASIO.
I have changed the outputs accordingly, without success.
If I create a new project, and import the audio, it works fine. There must be a setting in the project that is causing this problem.
Has anyone else experienced this? Any suggestions on how to work around this problem?
What software do you use for recording? You might want to try asking the same Q at their forums as well...
Just a thought...
Peace,
Thomas
