Can there be a univeral safe volume?
I found some patches here are ridiculously too loud. I think we should consider having a sort of univeral volume so we don't blow our ears out when trying a new patch. I primarily use headphones to play and make patches, on occasion I use my Fender Frontman amp. What I have done is set my master headphone volume on the back of the gnx at a reasonable level and compared volumes against the factory presets so that all my patches volumes are uniform. I do purposely make some patches quieter or louder depending on what it is but they shouldn't exceed more than the loudness of the factory presets. anyone agree?
But overall, I don't have a problem plugging into two small practice amps. I do this when I'm over at my parent's house and jam with my brother - his friend has a small Marshall, and my bro has my old (OLD) 10-watt bass amp by some unknown manufacturer (it was handed down to me, and before then it had been handed down several times). It sounds fine, no real degradation of sound, no need to switch SC on/off or anything like that.
As far as patch levels, I usually set the output volume halfway (on either the XLR or 1/4\"), then tweak the patch level to peak at around -3db (in PTP). Not the best way to do it, but certainly get the levels comparable.
Any time I'm trying out somebody else's patch, I'll turn down the last volume stage all the way unless I'm sure the patch won't kill the speakers/ears. So, if headphones, I'll turn down the XLR level; if stereo, I'll turn down output level on the stereo. Then I slowly turn it up until I'm sure it's not ridiculous in volume settings.
On GNX4 and 3k in general, patch level is an excellent way to get the sound you want without it being too soft or deafeningly loud. For example you might have a clean amp model that there's no way it's going to match your lead patch level, so you can use the overall preset level to balance it out.
- Ilia
