edirol ua 25 usb audio capture
has any one used or have one of these i,m thinking of getting one in the new year becouse my sound card card is not spdif.so thinking guitar>gnx3>mixer>amps>drum machime then ua 25 to pc usb.any advice would help.thanks.
Another thing I do is plug the RCA-out on the UA-25 into GNX3 CD-in (using a RCA-TRS cable) and jam along that way - works perfectly.
As far as recording digital, works fine except disables just about everything else on the unit. Likewise, there are other limitations to UA-25 such as if you're using digi-out you can't use direct monitoring, etc.
Plus, to go into it from a GNX3 you have to use a converter unit because the UA-25 is toslink and not coax like GNX. The adapter costs about $10 at radioshack (including power supply), but you'll need to get a lightpipe cable which could be more money depending on the brand and length (my 3-foot monster one cost $40). If you already have one for your home theater or something you could steal that!
But overall, UA-25 is a nice, portable unit that's pretty easy to set up for basic operations. As we speak, I have my GNX3 plugged directly into its combo jacks, going in stereo to a track on Sonar, plus GenEdit running from the UA-25 midi to/from GNX.
- Ilia
