Why EADGBE??
Can anyone tell me why \"standard\" tuning is EADGB? Is there some specific music theory involved that makes this the most optimal tuning, or
has it just become the most popular through common consent? :?
  • Fretboard Logic explains it all pretty good...
  • RevMoore, I'm sorry I can't answer your question but think it's a great one!
    AlbertA, Could you explain the logic behind standard tuning in more detail? I know very little about music theory but it is something I'm working on (not rapidly though, working on lots of things!).
    One thing I've never quite understood is the stagger on the the G string.
    I guess I'm doing an excellent job showing my ignorance!
    One more thing regarding my favorite string ( Not!! ). The good old G.
    Here's the deal, Is it just me or what? I pretty much judge the quality of a guitar based on whether or not the G string will stay in tune after you've bent it (vibrato included). My experience with the guitars that I've owned over the years,on the lower end, cheaper guitars,the G string would not stay in tune. Even the ones with locking trems. On the mid-level and high end (more expensive) guitars the G string will stay in tune even after taking a beating.
    Any info would be appreciated.
    Lee
  • Then Fretboard Logic is a book/series that you should pick up.
  • The tuning arrangement - more specifically, the intervals between strings - are, as shown in FL1/2, the way they are because it's the arrangement that yields a relatively convenient fingering for five chord shapes spanning 12 frets (i.e., all the \"inversions\"). Not only is the 3rd in the tuning a great convenience for voicings, but also its placement between second and third strings (and not any other two) allows for the most convenient fingerings.
    As far as why it starts with E, not sure. I'd guess it's a convention, but there might be rationale for it. One guess I had is that more keys than any other have one of E A D G B as a primary chord tone, so resonance is optimal - but that's a wild guess and I didn't test it. Perhaps most music was written in A or E, in the period of the development of today's classical guitar?
    The reason for G sounding weird is most likely due to the fact that the string next-thinnest is in a 3rd, which produces many more \"clashing\" overtones than a 4th does. Usually a good setup compensates for this issue.
    - Ilia
  • I may have something to do with many of the chords can be played in the open position with relative ease.
    It does, but only the interval aspect of it. In other words, the reason open position chords are relatively easy is because the tuning intervals are 4th-4th-4th-3rd-4th. It's also the reason why non-open position are likewise relatively easy to play.
    However, if you tune everything up or down, you'll have the exact same patterns and same relative ease of playing open positions (assuming you readjust your neck and use appropriate-gauge strings).
    Starting with E=E A D G B
    Starting with D=D G C F A
    Starting with C=C F Bb Eb G
    Starting with B=B E A D F#
    Starting with A=A D G C E
    Starting with G=G C F Bb D
    Starting with F=F Bb Eb Ab C
    Notice that the only ones that yield no shaps or flats on open strings are E, A, D. That's probably part of the reason why the particular tuning was chosen - you have the A (central of the three), to whom E is a dominant and D is a subdominant.
    Again, I'm just guessing.
    - Ilia
  • Thanks for the info. Any musical info is great appreciated by everyone on this board.
  • Hey guys below is a link that explains multiple tunings, pros and cons of different tunings, including standard tunings...
    http://lilytears.com/arts/music/guitar/methods/
    Also some good theory stuff on the site as well if you're interested...
    Even though the above link does not get into all the open tunings for blues slide, there are several links out there covering the subject as well. Personally I use standard tunings but when I used to play slide I'd use all kinds of open tunings to try to emulate my favorite blues slide player Johnny Winters...
    Hope the above link is of some help.
    See Ya,
    Tal
  • Read up on the circle of fifths..and also get familiar with fret trainer progs. there are many free online ones, and javascripts at wholenote.com
  • The FL approach tends to avoid general theory discussion (in the first two volumes especially) and focuses more specifically on the guitar. So, for example, Mr. Edwards says that learning \"chord inversion\" equivalent on guitar is pointless if you don't follow the guitar's unique tuning and resulting chord structure.
    However, it's important to understand inversion from a compositional/improvisational standpoint. wholenote.com has a chord dictionary that can tell you not only fret/string position, but also scale degrees and notes of each chord. What I would recommend is learning the inversions as follows:
    1. Start with any of the chord shapes (pick one and work on one at a time, don't go for all five from the start). For minor chords, as well as all manners of 7th chords, you may want to OMIT some of the notes in the chord shapes.
    2. You DON'T have to play all the notes of a chord; however, you must know which ones you do play to get the particular chord sound. For example, for a major chord, you definitely want the 3rd and the 5th. If you need a 7th chord, at the minimum you should have a 3rd or 5th and the 7th.
    3. Now, you will benefit from a list of notes in a chord. Here's an example: Emaj chord has E, G#, and B. So, if you played the C-shape Emaj chord (starting with root on 5th string, 7th fret), the notes are (from lowest to highest) E, G#, B, E, G#.
    4. This means that the next inversion of the chord, each of those notes will move up to the next chord tone: G# B E G# B. Move each note on its respective string UP the fretboard so that you have all those notes. http://www.44lbs.net/ilia/inversion_Emaj.txt
    5. NOW, as G3456 mentioned, you want to come up with the chord a 4th below and a 4th above each of the inversions. G-shape and E-shape chords (starting with root on 6th string, inverting the same way as steps 2-3). D-shape chords can be used for a 4th above, or you can take a partial E-shape starting with root on fourth string.
    The key goal with practicing the inversions together with circle of 5ths is to ensure that the total movement for all notes from chord to chord is as little as necessary. See the Yngwie cadence example in the link above - notice how the E chord goes into the Amin very smoothly - the total movement is only 3 semitones.
    Inversions are also useful for smoothing out voiceleading. See the Joe Stump climb at the end of the link above.
    A good, albeit complicated, book on the subject of chord voicing and voice-leading for guitar is Chord Chemistry by Ted Greene.
    Sorry for the OT, I just love explaining this stuff!
    - Ilia
