USB - MIDI
I currently have midi in my sound card, but I'm only able to connect 1 device to it. If I connect my GNX, and try to also connect my keyboard, the keyboard will NOT be recognized. I've tried every configuration and many different cables.
I have arrived at the conclusion that I'm better off adding a USB-Midi connector so I wont have to change the cables every time I want to connect the other device.
My question is (finally): Will a USB-midi device override the existing midi device or will I be able to use both devices (one connected to GNX, other to the keyboard)?
Any recommendations for a USB-Midi connector?
Soundcard midi out --> Synth Midi In
Synth Midi Through or Midi Out --> GNX Midi In
GNX Midi out --> back to Soundcard Midi In.
FWIW...I'm only using the keyboard/midi port on my Creative Audigy. Nothing fancy.
