Compact Flash for GNX4
Im a new owner of GNX 4
I found a lot of compact flash cards, but dont say if they are Type I,
And I want to know what is the maximum capaciy of the compact flash??
support 1 GB?
Please recommend me the best choice
support 1 GB?
I just bought the generic brand at my local store. Works fine. I forgot about the type 1 thing.
Cheers,
Kim.
I want to konow what is the maximum capacity of compact flash card that GNX4 can use.
Please help me with this, if colud you recommend me an specific compact flash.
http://www.amazon.com/gp/product/B0002TA96Y/102-3276927-4000951?v=glance&n=172282&v=glance
I didn't get mine from Amazon so this might not be the cheapest price.
If you're on a budget, you can save a lot of money by going with smaller cards, ones in the 256M to 512M range. A 2GB card is around $200, a 1GB card is $100. But you can get a 512MB (= 1.5 hours of recording time on the GNX4) for about $25 if you're willing to hunt around a little. So you can get 2GB of storage for half the price by buying four 512MB cards.
As far as which brands to buy, it probably doesn't matter at all. The chips inside those things are all probably made in the same four or five facilities, and then packaged in CF cartridges labeled with whichever vendor's logo. Also, audio data is pretty much insensitive to the most common memory hardware errors (single-bit inversions - no human is going to notice the difference if a few bits are flipped in a 1MB audio sample), so even if you get a low-quality chip that you wouldn't want to store your tax data on, it's probably still going to work just fine for recording.
Incidentally, I noticed that the GNX4 specs say it only supports CF cards 32MB and larger, but it accepted an old 16MB card I had lying around. Gave me a whopping 3 minutes of recording time...
-- JK
