64 bit drivers for GNX
I just put a new computer together and installed WinXP pro x64. I have installed Pro Tracks and the Xedit software with no probs, but the USB drivers for the GNX are not compatible with x64. I asked digitech tech support if they planned to produce any 64 bit drivers and the dude who replied had no idea what I was talking about and said \"the gnx is 24 bit and we don't intend to support 64 bits\" (reference the audio sampling rate)...
so the question is, who has ideas about a solution for this problem? No doubt any new studio computer equipment is going to be running a 64 bit OS so it will have to be addressed at some point, but I'm dead in the water in the meantime.
my advice is never put latest os when they r 1st shown in retails.... coz as it happened to u u'll be stuck.... the very new is like the very old.. u dt havin nethin that runs over-them
now i need to ask u a q.... wht is different bout the x64 pro?
I know the pentium can be power down 2 regular as aposed to 64
Athlons the 3500 series and up are supost to suport everything from 34 bit world to 64 bit world?
This post I am sure some one can answer this question. Also I have called digitech and can be pretty helpful.
Same problem here : I bought a windows xp pro 64, to take advantage of my new Athlon X2 3800+.
I especially bought the GNX3000 because it was also a soundcard.
But the bundled drivers don't work.
Someone @ the Digitech support assured me the WDM drivers would work and the ASIO for 64bit was under development...
Well neither the WDM nor the ASIO install...
I have win xp pro 64 SP2, .NET framework 1.1, I got all microsoft patches so my OS is up to date.
Anyone got a solution ?
Thanks a lot
Seems to finally work
I emailed Digitech support to ask some more info.
They told me :
I didn't have to reset, I tried, I didn't want to lose some presets, it worked !
For the rest, I followed the procedure written around page 109.
I should look for some info on how to tweak to decrease latency, but the ASIO4ALL ASIO driver works with the GNX3000 !!!
Now, you said you are running 32 bit software and it works fine but not the usb. That is because software is different from hardware. You can run 16 bit software on a 64bit chip. Hardware has to have drivers they are the same bit depth as the operating system (or atlest that's what the OS developers told me). You can install win XP 32 and run the drivers you have, but then you are really running a 3500 32 bit chip because windows can not access the other 32 bits of the chip.
yes, I know, I am a computer geek. Any how, it shouldn't take them very long to write the drivers. However you may be stuck until the demand for the drivers increases. Good Luck.
Side note for you. The PowerMac G5's are 64 bit and they are supported.
