X-Edit version 2
Anyone know when the X-edit version 2 is due out..
Alberto mention it in the other forum but I couldnt find any mention of it
Zak :roll:
  • sup zak...
    still no info about the x-edit?
  • I wonder if they will fix the infamous pedal/program shutdown bug that you all talk about.
  • You would think with such a bug they would have announced something, Imagine buying a computer and then while you were using it, it just crashes for no reason.....
    Hang on, that shit happens all the time
    Damm, there goes my argument
    Zak :shock:
  • This is the most annoying bug, any word on this Digi :?:
  • I explained on the old GNX3000 forum why this might happen. I'll see if I can resurrect the post.
    \AlbertA\ wrote:
    No USB 1.1 is fine. It's the MIDI spec which requires a speed of 31250 bits per second. Each MIDI byte is 10 bits, so you can transmit 3125 bytes/second
    Now every time you update the expression pedal a sysex message is generated. I've seen it take about 10-20 bytes.
    Normally the expression pedal has a resolution of 100 steps. So one full sweep from toe bottom to toe up is = 100 X 20bytes = 2000 bytes. Now rock the pedal a few times, you'll notice it takes you less than a second right? So one full rock back and forth is about 2000 - 4000 bytes !!
    But the maximum theoretical transmission with MIDI is 3125 bytes/second!!
    So one solution is either reduce the resolution in the expression pedal updates (at least while transmitting or don't do anything (which is why I suspect that with the GNX4, the messages get corrupted and X-Edit crashes because of this).
    If you ever updated a hardware synthesizer by sysex and wondered why it takes such a long time, well It's because of the old MIDI standard.
    X-Edit communicates through MIDI sysex (wrapped in a USB stream) with the GNX4, and GNX3000.
  • Ok it has been long enough we the gnx4 users want x-edit 1.3 can you please put up in the download section. We want the new functions.
    I second this. I don't even use X-Edit 1.2, it's just not worth the trouble. AlbertA, you don't have to rock the pedal back and forth to trigger the \"Comm error detected\" crash -- often merely bumping the pedal by accident will do it. And it sucks not to be able to audtion pedal assignments while running X-Edit. Like, does it sound better to assign flanger depth or flanger level to the pedal? I can't make that decision while editing presets in X-Edit, 'cause the mofo will crash as soon as I touch the pedal.
    As long as I'm not actually saving a preset or doing a sysex dump, I don't even care that the \"Comm error\" occurs -- and I certainly don't want X-Edit to bother me with it and then lock up! A subtle \"Dude, there was a comm error, do you care?\" message in a status bar somewhere would be more than sufficient.
    Cheers,
    -- JK
    Cheers,
    -- JK
    Yeah, the expression pedal bug is gone from 1.3 as far as I can tell.
  • the 1.2 is ok but why wait when something better is out already!!! I made 3 new patches with 1.2 today. Hmm come to think of it when I hit the expression pedal it did not crap out on me either.....strange. Also programed parameters for A,B and C buttons. Great tool. Thanks too some awesome tuterals by G3456!!! Yeah that guy rocks!!!
    But I really want the 1.3 version please digitech give us a download.
    PLEASE DIGITECH GODS realease the power of 1.3 x-eDIT!!!!@! :shock:
  • It's not the official way, but Albert posted the V1.3 binaries at:
    http://gnx4.org/downloads/software/?dl=software/X-Edit_1.3.zip
    along with some appropriate caveats.
    I saved all the V1.2 files and just dropped the new ones on top. Worked great! But, the virtual memory leak is still there :( (new splash screen is cool though...)
    - g
  • I'm not sure why, but I've got version 1.3. I was having some issues with my pedal and the drivers and while talking with tech support the guy said he would e-mail me the latest version of X-Edit, he did. Anyway, I have no problems posting it up here, (as long as it won't cause any issues from digitech?)
    Let me know.
    And yes,
    1. There is still a memory leak.
    2. The new splash screen looks cool.
    Ditto... I don't have any problems along these lines.
  • i downloaded the binary and just cut and pasted it into the x-edit folder works fine..... However i cannot open patches from others site like alberta's. it crashes about half as much as its predessor.
    Would you care to elaborate?
  • ok,
    instead of having:
    [code:1]<?xml version=\"1.0\" encoding=\"utf-8\"?>
    <?xml-stylesheet type=\"text/xsl\" href=\"Gnx4Preset.xsl\"?>
    <Gnx4Preset SchemaVersion=\"1.1\" xmlns=\"http://www.digitech.com\">[/code:1]
    as your header you have:
    <Gnx4Preset SchemaVersion=\"1.2\" xmlns=\"http://www.digitech.com\">[/code:1]
    and x-edit cannot open it.
  • ok,
    instead of having:
    But 1.3 should open it fine tough...
    In any case if you use the g4pfix utility I posted it will correct that...
