Home DigiTech Forum DigiTech Products
Jamman JML2V issue with Rhythm
I just received this today and have been playing with it for hours, on the 1st memory location. When I got done, I switched to 2, and hit the record button, but the rhythm came through, but I didn't want it. I turned the Rhythm level down all the way and tried again, and again, it came through just as loud. It is at the same level no matter where the level control is set. So basically, memory location 2 is unusable. Moving on to 3...same thing, different rhythm. Same thing happens on 2-11 locations. They each have a different rhythm, but it cannot be changed or turned off. In fact, if I go to Rhythm Type, they are all set to Off! What am I missing? All other locations seem fine through 30 anyway. Did a factory reset. Tried to hold down the clear button, it goes through the paces but the Rhythm persists.
  • Hmmm... OK...something new. Not thrilled about it, but I get it. 2-11 are backing tracks that you can use, drums and bass. The Rhythm that you can select goes on top of that backing band, and that is controlled by the level and type. But it basically means the 2-11 are useless. There is no way to use those banks without the backing tracks. Unless there is something wrong, like the operator.
    Any help is appreciated.
