Custom setup on Driverack PA2?
Hello, I am new to using a driverack. I want to hook up 2 QSC KW153, 2 QSC KW181 and 2 QSC KSubs. I am not sure how to set that up in the driverack. Any help would be great.
  • While mixing subs is normally frowned upon....
    I would set up as if it were a 3-way system. One sub type on Mids and one type on Lows. Then adjust the filters so that the Mid and Low are both the Lows. This will allow separate gain staging, and allow output PEQ's to tune separately, as well as limiters, etc.
