stereo subs only detecting one side
Hi and thanks in advance.
I have a DRPA2 driving 2 x Yamaha P7000s' into 4 x Yamaha c115v's and 4 x CW118v's in stereo tops and subs.
All was well then the wizard stopped detecting the 'chirp' in the right sub in stereo sub mode. I swapped out cables and amps but still no test sig being sent to right subs. I then reconfigured for mono subs and switched from stereo to parallel input on the sub amp. All worked fine!
Is this a time for repair of the DRPA2 or is there something else I'm missing here to get my stereo subs working.
ta
Pete
ta
Pete
Anyway, I would call tech support. They don't monitor this forum (usually).
yes. the chirp was working in both subs originally.
